Displays ELRP information.
N/A.
| Client |
Displays the name of the ELRP client. |
| VLAN |
Displays the name of the VLAN with ELRP enabled. |
| Ports |
Displays the set of VLAN ports used for packet transmission. |
| Interval |
Displays the configured interval. An interval of 3 indicates that ELRP PDUs are transmitted every 3 seconds. |
| Count |
Lists the configured number of ELRP PDUs that are transmitted. The PDUs are transmitted at the configured interval. This method of ELRP PDU transmission is used by ESRP in the pre-master state. A count of 0 indicates continuous PDU transmission. If the Cyclic value is Yes, the count is always 0. |
| Cyclic |
Indicates whether ELRP PDUs are being continuously sent. The column shows Yes for the master VLAN because that VLAN is continuously sending ELRP PDUs for loop detection. When a VLAN is in the pre-master state, it only sends three ELRP PDUs before changing to master or slave. During this time the column shows No for that VLAN. |
| Pkts-Xmit |
Displays the number of ELRP PDUs transmitted. |
| Pkts-Rcvd |
Displays the number of ELRP PDUs received. |
| Action |
Displays the configured action the switch takes when ELRP messages are received back indicating a detection of a network loop or no packets are received within the specified duration. The following list describes the actions: Print (P)—Specifies that the switch prints a message to the console.Log (L)—Specifies that the switch sends a message to the system log file.Trap (T)—Specifies that the switch sends a message to the SNMP manager.Callback (C)—Specifies a callback action. If you use ELRP with another protocol (for example ESRP), ELRP uses a callback action to notify the protocol of a loop detection. |
| Disable Port |
Displays the configured hold time (number of seconds or permanent) for a port that was disabled with the configure elrp-client periodic command. When the time in seconds expires, the port is automatically enabled. |
With hardware-assisted ELRP, one ACL egress counter is used to record ELRP PDUs transmitted per VLAN port, and the displayed Pkts-Xmit is calculated after all egress counters are queried from hardware. If show commands are executed very frequently, the statistics might not change every time.
The following example displays summary ELRP status information on the switch:
# show elrp
ELRP Standalone Client: Enabled
ELRP Inter-VLAN loop detection: On
ELRP client hardware assist: Enabled
Loopback port: 1
Number of ELRP sessions: 1
Number of ELRP pkts transmitted: 0
Number of ELRP pkts received: 0
Interval Pkts Pkts Disable
Client VLAN Ports (sec) Count Cyclic Xmit Rcvd Action Port (sec)
CLI Default All, 1.0 0 Yes 0 0 LT -
All VXLAN RTEPs
This command was first available in ExtremeXOS 11.1.
VXLAN remote endpoint information was added in ExtremeXOS 22.4.
Hardware-assisted ELRP information was added in ExtremeXOS 30.3.
